Managing the Enterprise Projects of Vaults
You can group your vaults using enterprise projects or change the enterprise project where your vault belongs whenever needed.
To change the enterprise project of a vault, find the current enterprise project, then move the vault out of it, and finally add the vault to a new enterprise project.
- Click Enterprise on the upper right of the console page. By default, the Overview page of Enterprise Management is displayed.
- In the navigation pane of the Enterprise Management page, choose Project Management.
- Locate the enterprise project from which the vault will be removed. Click View Resources in the Operation column. On the Resources tab, view resources in the current enterprise project.
- Select the resources to be removed and click Remove. On the displayed page, select Independent resources for Mode.
Under this mode, resources are removed individually, and multiple can be removed at once. For details, see Removing Resources from an Enterprise Project.
- Select the destination enterprise project to which the vault is to be added and click OK.
After the vault is removed from the enterprise project, you can view it in the resource list of the destination enterprise project.
