Managing Vault Tags
You can add, edit, or delete tags of a vault. Vault tags are used to filter and manage vaults only.
If your organization has enabled the tag policy type for CBR and has a tag policy attached, you must comply with the tag policy rules when creating vaults, otherwise vaults may fail to be created. Contact the organization administrator to learn more about tag policies.
- Log in to the CBR console.
- In the upper left corner, click
and select a region. - Click
and choose Storage > Cloud Backup and Recovery.
- On the Vaults tab, click the name of the target vault and then select the Tags tab.
- Adding a tag
- Click Add Tag in the upper left corner.
- In the displayed dialog box, enter the key and value of the new tag.
Tags are key-value pairs, which are used to identify, classify, and search for vaults. You can add a maximum of 20 tags for a vault, and vault tags are only used for vault search and management.
Table 1 describes the parameters of a tag.Table 1 Tag parameter description Parameter
Example Value
Key
Tag key. Each tag of a vault has a unique key. You can customize a key.
A tag key:
- Can contain 1 to 36 Unicode characters.
- Can contain only letters, digits, hyphens (-), and underscores (_).
Key_0001
Value
A tag value can be repetitive or left blank.
A tag value:
- Can contain 0 to 43 Unicode characters.
Value_0001
- Click OK. After the tag is added, it is displayed in the tag list.
- Editing a tag
- In the Operation column of the tag that you want to edit, click Edit.
- In the displayed Edit Tag dialog box, enter a new tag value. Table 1 describes the parameters.
- Click OK. After the tag is edited, you can view the tag in the tag list.
- Deleting a tag
- In the Operation column of the tag that you want to delete, click Delete.
- In the displayed dialog box, confirm the deletion information.
- Click OK. After the tag is deleted, the tag is not displayed in the tag list anymore.
- Adding a tag
