Help Center/
Cloud Bastion Host/
User Guide/
Managing Instances/
Key CBH Instance Operations Recorded by CTS/
Viewing CTS Traces
Updated on 2025-09-04 GMT+08:00
Viewing CTS Traces
After CTS is enabled, the system starts recording operations of CBH. Operation records for the last seven days can be viewed on the CTS console.
- Log in to the CTS console.
- Click
in the upper left corner on the displayed page and select a region. - On the left navigation pane, choose Trace List.
- Specify the filters used for querying traces. The following filters are available:
- Trace Source, Resource Type, and Search By
- Select a search criteria from the drop-down list box. For example, choose CBH > cbh > Trace Name > createInstance, and click Query to query all instance creation operations.
- Trace Name: Select a trace name, for example, createInstance.
- Resource ID: Select or manually enter the ID of a CBH instance whose logs are to be viewed.
- Resource Name: Select or manually enter the name of a CBH instance whose logs are to be viewed.
- Operator: Select a specific operator (a user rather than tenant).
- Trace Status: Available options include All trace statuses, normal, warning, and incident. You can only select one of them.
- You can specify start time and end time query traces during a time period.
- Click
on the left of the trace to be queried to extend its details. - Click View Trace in the Operation column for details.
Parent topic: Key CBH Instance Operations Recorded by CTS
