Updated on 2026-08-11 GMT+08:00
Deleting an Instance
You can delete a CBH instance if you no longer need it or if it is faulty.
Precautions
Deleted instances cannot be restored. Exercise caution when performing this operation.
Notes and Constraints
Yearly/Monthly instances can be deleted only when they are in the Faulty or Abnormal state.
  1. Log in to the CBH console.
  2. Click in the upper left corner on the displayed page and select a region.
  3. Locate the target instance. In the Operation column, choose More > Delete.
  4. In the displayed dialog box, click OK.
    Deleted instance are no longer displayed in the instance list.
