Updated on 2025-09-29 GMT+08:00
CBH Monitoring Metrics
This topic describes metrics reported by a bastion host to Cloud Eye as well as their namespaces. You can use Cloud Eye to query the metrics of the monitored objects and alarms generated for your bastion hosts.
Only CBH V3.3.30 and later versions can be interconnected with Cloud Eye.
Namespaces
SYS.CBH
A namespace is an abstract collection of resources and objects. Multiple namespaces can be created in a single cluster with the data isolated from each other. This enables namespaces to share the same cluster services without affecting each other.
Metrics
Table 1 Bastion host metrics
Metric ID
Metric Name
Value Range
Unit
Number System
Dimension
Monitoring Period (Original Metric)
cpu_util
CPU Usage
Measures the CPU usage of the physical server accommodating the monitored ECS, which is not accurate as that obtained on the monitored ECS.
0%~100%
N/A
server_id
300s
mem_util
Memory Usage
Memory usage of the monitored object
0%~100%
N/A
server_id
300s
disk_util
Disk Usage
Disk usage of the monitored object
0%~100%
N/A
server_id
300s
session_count
Session Connections
Number of session connections of the monitored object
≥0
N/A
N/A
server_id
300s
resource_count
Managed Resources
Total number of resources managed by the monitored object
≥0
N/A
N/A
server_id
300s
Dimensions
Key
Value
server_id
CBH instance ID.
To obtain this value, see Checking Instance Details.
