Sharing a VPC
To use CBH to manage ECSs, the ECSs and the CBH instance you are using must be in the same VPC.
Step 1: Create a VPC
- Log in to the RAM console.
- In the navigation pane on the left, choose . The Resource Shares page is displayed.
- Click Create Resource Share in the upper right corner.
- Set resource type to vpc:subnet, choose the corresponding region, and select the VPC to be shared. Click Next: Associate Permissions.
- On the Associate Permissions page, associate a RAM managed permission with each resource type, and then click Next: Specify Principals in the lower right corner.
- Specify the principals that you want to have access to the resources on the displayed page. Then, click Next: Confirm in the lower right corner.
Table 1 Description Parameter
Principal Type
- Organization
For details about how to create an organization, see Creating an Organization.
NOTE:If you have not enabled resource sharing with organizations, this parameter cannot be set to Organization. For details, see Enabling Sharing with Organizations.
- Huawei Cloud account ID
- Organization
- Check the configurations and click OK in the lower right corner.
Step 2: Use a VPC
- Log in to the CBH console.
- Click
in the upper left corner on the displayed page and select a region. - Click Buy CBH Instance to go to the Buy CBH Instance page.
- Configure instance parameters as required. You can select the VPC created in Step 1: Create a VPC for VPC.
