Help Center/ Cloud Bastion Host/ User Guide/ Resource Operation/ OM Task/ Managing OM Task Execution Logs
Updated on 2024-09-24 GMT+08:00
After an OM task is executed, an execution log is generated. You can view the task execution result in the log, including the execution results and details.
This topic describes how to manage execution logs, including viewing, downloading, and deleting execution logs.
You have the management permissions for the OM Task module.
Viewing Log Details
  1. Log in to your bastion host.
  2. Choose Operation > OM Task > Execution Log to go to the task list page.
  3. Query OM task execution logs.
    Quick search: Enter a keyword in the search box and search for O&M tasks by task name.
  4. Select the task you want and click Detail in the Operation column.
    • In the Basic Info area, view the basic information and brief result of the operation task.
    • In the Execution Details area, view and export the detailed execution result of the OM task.
Downloading OM Task Execution Logs
  3. Select the task you want and click Download in the Operation column to download the execution log in CSV format.
  4. Click View to go to the task details page.
    You can view the basic information and brief execution result of an operation task. In the execution details area, you can view and export the detailed execution result of an operation task.
  5. Click Export to download the current execution log file in CSV format to the local computer.
  6. To delete one execution log, select the one you want and click Delete in the Operation column to delete it.
    To delete multiple execution logs at a time, select the ones you want and click Delete at the bottom of the list to delete the selected logs together.
Deleting Execution Logs
  3. To delete on task logs, select the one you want and click Delete in the Operation column to delete it.
  4. To delete multiple execution logs at a time, select the ones you want and click Delete at the bottom of the list to delete all selected logs together.
