Updated on 2026-09-17 GMT+08:00
Viewing and Managing Execution Logs
After a synchronization rule is executed, execution logs are generated accordingly. You can view the account synchronization result in the execution logs, including the synchronized account information, new account information, and deleted account information.
You have the operation permissions for the Sync Rules module.
Viewing Log Details
  1. Log in to your bastion host system.
  2. Choose Policy > Sync Rules > Sync Log.
  3. Query OM task execution logs.
    Quick search: Enter a keyword in the search box and search for execution logs by rule name.
  4. Select the execution log and click Detail.
    You can view the basic information, host details, account list for synchronizing passwords, and account list for synchronizing SSH keys.
    Figure 1 Viewing the basic information
Downloading OM Task Execution Logs
  3. Select the execution log and click Download to download the log in CSV format.
Deleting Execution Logs
  3. Select an execution log and click Delete in the row to delete it.
  4. To delete multiple execution logs at a time, select the ones you want and click Delete at the bottom of the list to delete all selected logs together.
