Help Center/ Cloud Bastion Host/ User Guide/ Resource/ Defining a Custom Resource OS Type
Updated on 2026-07-30 GMT+08:00
A bastion host can manage resource OS types and allows you to define custom operating system (OS) types.
You can add tags to OS types and then group and manage resources by those tags. With OS type tags, you can change server passwords, store password change parameters, and run password rules for resources of a certain OS type at the same time.
A bastion host can manage 14 OS types by default, including Linux, Windows, Cisco, Huawei, H3C, DPtech, Ruijie, Sugon, Digital China sm-s-g 10-600, Digital China sm-d-d 10-600, ZTE, ZTE5950-52tm, Surfilter, and ChangAn.
  • Only system administrator admin can modify the OS type configuration.
  • The default OS type cannot be deleted or modified. Only the customized OS types can be deleted or modified.
Customizing OS Types
  1. Log in to your bastion host system.
  2. Choose Resource > OS Type to switch to the OS type list page.
  3. Click New to switch to the New OS Type dialog box and configure parameters.
    Table 1 Parameters for creating an OS type
    OS Type
    Specifies the name of the custom OS type.
    Chpw Param
    Specifies the command of changing the account password and its return value. A maximum of 16 commands can be added.
    • password indicates the old password.
    • new_password indicates the new password.
    • change_user indicates the account whose password needs to be changed.
    • Brackets are not allowed.
    Chpw Param for Sudo Login
    Specifies the command of obtaining the permission for changing the account password and its success return. A maximum of 16 commands can be added.
    Remarks
    Provides brief introduction about the OS type.
  4. Click OK. The newly created OS type will be displayed in the OS type list.
  5. Manage customized OS types.
Other Operations
  3. Delete a customized OS type.
    • To delete an OS type, click Delete in the Operation column of the row where the OS type locates.
    • To delete multiple OS types, select the ones you want to delete and click Delete at the bottom of the OS type list to delete them together.
  4. View and edit the customized OS type configurations.
    1. Click the name of the OS type you want to edit or click Manage in the row of the OS type in the Operation column.
    2. Click Edit in the Basic Info area to edit the basic information of the OS type.
