Help Center/ Cloud Bastion Host/ User Guide/ System Configuration/ Login Security Configuration/ Enabling API Configuration (Included in V3.3.34.0 and Later Versions Only).
Updated on 2026-07-30 GMT+08:00
After you enable the API configuration, you can use your bastion host by calling APIs.
You have the management permissions for the System module.
- Log in to your bastion host system.
- Choose System > System Config > Security.
- In the API Config area, click Edit.
- Click
. - Click OK.
Parent topic: Login Security Configuration
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
