Viewing System Configuration Information
This topic walks you through how to view basic system information.
You have the management permissions for the System module.
- Log in to your bastion host system.
- In the navigation pane on the left, choose .
- View basic system information.
Table 1 System parameters Parameter
Product Name
Bastion host
Product ID
Unique authentication code of a product
Service Code
Your bastion host service code. This code is used by technical personnel to log in to the system background and manage the background. This parameter is available only for single-node bastion hosts.
- Click View to obtain the code. Keep your service code secure. Do not send it to any public information platforms.
- When technical personnel use the service code to log in to the system backend, a login record will be added to the bastion host system operation log.
Current Host Service Code
Your primary bastion host service code. This code is used by technical personnel to log in to the system background and manage the background. This parameter is available only for primary/standby bastion hosts.
Current Standby Service Code
Your standby bastion host service code. This code is used by technical personnel to log in to the system background and manage the background. This parameter is available only for primary/standby bastion hosts.
- Click View to obtain the code. Keep your service code secure. Do not send it to any public information platforms. Before the password of admin for the standby bastion host is changed, if the service code is empty, the service code of the standby bastion host is the initial password of admin.
API Access Key
Used for node authentication on the unified management platform.
- When you click View or Clear, you need to enter the login password of the current user.
- When you click Update, you need to enter the login password, access key ID, and access key secret of the current login user. After the update, the node managed by the unified management platform will become invalid.
HA Key
Used to configure the HA
When configuring the standby node for HA on the web interface, connect the programs on the standby node to the specified active one, perform the validity check based on configuration information, and then modify the configuration on the active node after the validity check is passed.
Version
Version of the instance.
Device System
Version of the current system software
Issue Time
Release date of the instance.
