Help Center/ Cloud Bastion Host/ User Guide/ Login Security Configuration/ Configuring Automatic Inspection (Available in V3.3.36.0 and Later)
Updated on 2025-03-12 GMT+08:00
After automatic inspection is enabled, the system automatically verifies accounts of managed resources at 01:00 on the 5th, 15th, and 25th days of each month.
You have the management permissions for the System module.
  1. Log in to your bastion host.
  2. Choose System > System Config > Security.
  3. In the Auto Inspect Config area, click Edit.
  4. By default, automatic inspection is enabled. You can click to disable it.
  5. Click OK.
