Updated on 2025-04-16 GMT+08:00
System Diagnosis
On the system diagnosis page, you can easily check the status and details about the bastion host, including overall information and details about system load, kernel, memory, network interface card (NIC), disk usage, routes, and ARP.
You have the management permissions for the System module.
  1. Log in to your bastion host.
  2. Choose System > System Maintain > System Diagnosis.
  3. Select an information type and then click Fetch to view the details.
    Table 1 System diagnosis parameters
    system overview
    Obtains overview information about the bastion host, including memory, I/O, and CPU.
    system load
    Obtains information about the bastion host load.
    system kernel
    Obtains information about the system kernel.
    memory summary
    Obtains information about the system memory.
    network interfaces
    Obtains information about the system NIC.
    disk usage
    Obtains information about the disk usage of the system.
    route table
    Obtains route information about the system.
    ARP table
    Obtains ARP information about the system.
    Figure 1 System Diagnosis
