Configuring the Netdisk Capacity
The Netdisk is used to temporarily store files from managed hosts or the local server for the purpose of file transfer. The Netdisk is a personal net disk in a bastion host.
This topic describes how to set the net disk capacity.
- The maximum available space of the net disk is the available space of the system data disk.
- After Personal Netdisk is set, the bastion host allocates the same personal net disk capacity for each user in the system.
- Files on the Netdisk can only be manually deleted. Periodic clearance of personal net disk space is not supported.
You have the management permissions for the System module.
- Log in to your bastion host.
- Choose System > Data Maintain > Storage Mgmt to go to the storage configuration page.
- In the Netdisk area, click Edit. In the displayed dialog box, set the disk size.
    Table 1 Netdisk parameters Parameter Description Personal Netdisk A private disk exclusively used by the current user - The default value is 100 MB.
- To use the personal net disk unlimitedly when the system data disk capacity is allowed, set Personal Netdisk to 0.
 Total Netdisk Total netdisk capacity. - The default value is 5120 MB.
- To use all space of the total net disk unlimitedly when the system data disk capacity is allowed, set Total Netdisk to 0.
- Click OK. You can then view capacity of the configured Personal Netdisk and Total Netdisk on the Storage Mgmt tab.
- Click Detail and view details about the net disk.
- In the row containing the net disk, click Delete NetDisk Data in the Operation column.
      You can also select all net disks from which you want to delete data and click Delete NetDisk Data to clear the disks together.
