Changing the System Theme
On the theme tab, you can customize the page language and system and company logos you want to display for your bastion host.
You have the management permissions for the System module.
Theme
- Log in to your bastion host.
- Choose System > System Config > Theme.
- Switch over the system language.
- On the displayed page, in the Language settings area, click Edit.
- Select a language. You can select simplified Chinese or English.
- Click OK.
Then, log out the system, clear cookies, and log in to it again for the specified language to take effect.
Changing language in the upper right corner on the login page takes effect immediately.
- Change the system logo.
- In the Logo settings area, click Edit.
- Click logos under System logo and Company logo, respectively, open the local path, and select a logo you want to use.
- Click OK. Then you can check the system logo and company logo on the Theme tab.
