Updated on 2024-09-24 GMT+08:00
Configuring Alarm Sending
This section describes how to configure the alarm sending scope.
You have the management permissions for the System module.
  1. Log in to your bastion host.
  2. Choose System > Sysconfig > Alarm.
    Figure 1 Alarm
  3. In the Alarm Sending Configuration area, click Edit.
    • Select This Department or The department and all superior departments to which the alarm notification is sent based on the alarm notification range.
    • Alarm notifications can be sent to system administrators. You can determine whether to send alarm notifications as needed.
    Figure 2 Alarm sending configurations
  4. Click OK. You can then view alarm sending configuration on the Alarm tab.
    Figure 3 View the alarm sending configurations.
