Help Center/
Cloud Bastion Host/
User Guide/
Instance Configuration/
Alarm/
Configuring Alarm Levels
Updated on 2025-03-12 GMT+08:00
You can configure the alarm levels, alarm mode, and alarm sending scope.
You have the management permissions for the System module.
- Log in to your bastion host.
- Choose System > System Config > Alarm.
Figure 1 Alarm configuration
- In the Alarm Level area, click Edit.
- In the displayed Alarm Level dialog box, configure alarm severity levels for different types of messages in each tab.
- The alarm level can be high, medium, or low.
- Click OK. You can then view alarm level configuration on the Alarm tab.
Parent topic: Alarm
