Configuring the SSH Console Port
The SSH console port is required for logging in to your bastion host through an SSH client. The default port is 22.
If you change the default port, modify the port configured in the security group of the instance accordingly.
This topic describes how to configure an SSH console port.
You have the management permissions for the System module.
- Log in to your bastion host.
- Choose System > System Config > Port.
- In the SSH Console area, click Edit.
    In the displayed SSH Console dialog box, configure the port for accessing the SSH client. The default port is 22.
- Click OK and then restart the system for the configuration to take effect.
