Configuring the Web Console Port
The web console port is used for logging in to your bastion host through a web browser. The default port is 443.
If you change the default port, modify the port configured in the security group of the instance accordingly.
This topic describes how to configure a web console port.
You have the management permissions for the System module.
- Log in to your bastion host.
- Choose System > System Config > Port.
- In the Web Console area, click Edit.
In the displayed Web Console dialog box, configure the port for accessing the web browser. The default port is 443.
- Click OK and then restart the system for the configuration to take effect.
