Help Center/ Cloud Bastion Host/ User Guide/ System Configuration/ Login Security Configuration/ Configuring the RDP Resource Client Proxy (Available in 3.3.26.0 and Later Versions)
Updated on 2026-07-30 GMT+08:00
If a server with the RDP protocol configured attempts to connect to the bastion host over RDP, the security layer verification is used. You can select a security layer verification mode.
You have the management permissions for the System module.
  1. Log in to your bastion host system.
  2. Choose System > System Config > Security.
  3. In the RDP resource client proxy Configuration area, click Edit.
  4. In the Security layer drop-down list, select a client proxy and click OK.
    You can select RDP, TLS, or Negotiate.
