Configuring Policies to Disable Certain Users (Available in V3.3.30.0 and Later)
The zombie user policy function allows you to identify zombie users and customize a threshold time range. If a user does not log in to the system within the configured threshold time range, the system marks the user as zombie and disables the user. Only the administrator can enable the zombie user. The default threshold is 30 days. If the threshold is set to 0, all users are disabled immediately.
You have the management permissions for the System module.
- Log in to your bastion host.
- Choose System > System Config > Security.
- In the UserDisabled Config area, click Edit.
- Disable zombie users: By default, this function is disabled. After this function is enabled, the status is
- Determines the zombie user time: The value ranges from 0 to 10,080. The default value is 30 days. If the value is set to 0, all users are disabled immediately until the administrator cancels the disabling. For details about how to enable users, see Enabling or Disabling a User.
- Click OK.
