Configuring the Login Password Rules
This topic describes how to configure the user password policies, including the password strength, number of password verification times, and password change period.
You have the management permissions for the System module.
- Log in to your bastion host system.
- Choose System > System Config > Security.
- In the Password Config area, click Edit. Complete configurations as prompted.Figure 1 Password Config
Table 1 Parameters for configuring a password rule Parameter
Strength check
Checks password strength. It is enabled (
) by default.
: disabled
: The password can contain 8 to 32 characters and must contain at least three types of the following characters: uppercase letters, lowercase letters, digits, and special characters !@$%^-_=+[{}]:,./?~#*.
First logon change
Forces a user to change password upon first login to the system. It is enabled (
) by default.
: disabled.
: enabled.
Sameness check
Prohibits the reuse of the latest N passwords.
- The password used for initial login is not counted.
- Default value: 5
- Value range: 1 to 30
Change cycle
Password validity period. Users will be forced to change their passwords upon expiry.
- Default value: 30 days
- Value range: 0 to 90, in days
- If the value is 0, the password never expires.
- Click OK. You can then check the password rule of the current system user on the Security tab.
