Updated on 2025-03-12 GMT+08:00
Pushing Operation Reports
For your convenience of audit, you can manually export the operation reports or enable the auto send function to let the bastion host push operation reports to you through emails at the interval you select.
  • Operation reports can be automatically sent by the day, week, and month.
  • The report format can be PDF, DOC, XLS, or HTML.
  • An operation report for a maximum of 180 consecutive days can be pushed each time.
Manually Exporting an Operation Report
  1. Log in to your bastion host.
  2. Choose Audit > Operation Report.
  3. Click Export in the upper right corner of the page.
  4. In the displayed Export dialog box, configure the method and time to export the report and the report format.
    Table 1 Parameters for exporting operation reports
    Granularity
    Time granularity for displaying the trend chart of the operation report.
    The options are Hourly, Daily, Weekly, and Monthly.
    Time
    Start time and end time to generate the operation report to be exported.
    • Start time and end time are mandatory.
    • A maximum of 180 consecutive days are allowed.
    Report Type
    Type of operation statistics to be included in the operation report.
    File format
    Format of the report. You can select only one format.
    • DOC is selected by default.
    • You can download a report in PDF, DOC, XLS, or HTML.
  5. Click OK to export the operation report immediately.
Automatically Pushing a System Report
  3. On the displayed page, click Auto Send in the upper right corner.
  4. In the displayed Auto Send dialog box, configure the method and time to push the report and the report format.
    Table 2 Auto Send
    Status
    Whether to enable the auto send function. This function is disabled by default ().
    • : indicates that auto send function is disabled.
    • : indicates that the auto send function is enabled. The operation report of the previous period will be sent to you through emails.
    Send cycle
    Interval at which a report is sent.
    • By default, the report is sent at 00:00 on the specified date.
    • Reports can be sent by the day, week, or month.
    • Statistics in the daily reports are displayed by the hour.
    • Statistics in the weekly reports are displayed by the day.
    • Statistics in the monthly reports are displayed by the week.
    File format
  5. Click OK.
