Text Audit
Each time an operation is finished, a historical session is generated to record the specific operations performed by the operator. Auditors can view these historical sessions to check whether operators performed any non-compliant operations during the O&M process.
The entire process of O&M personnel logging in to managed resources through the bastion host is recorded as detailed text data. Auditors can view the records online or export historical session records in just a few clicks.
Notes and Constraints
For details about the resource types that support text audit, see Audit Formats.
The role you belong to has the management permission for the History Session module. For details about how to check the permissions of each role, see Role.
Searching for and Viewing Historical Session Records
- Log in to your bastion host system.
- In the navigation pane on the left, choose to go to the historical session list page. Figure 1 Historical session list
- Configure search criteria to filter historical sessions. Figure 2 Configuring search criteria for historical sessions
- Basic search
Select a search attribute from the drop-down list on the left, such as the resource name, resource account, user, or source IP address. Enter a keyword in the search box and click
or press Enter. - Advanced search
Click Advanced to expand all advanced search attributes. Enter keywords in the search boxes of the corresponding attributes and click Search.
- Basic search
- View historical session details.
Click Details in the Operation column of the target historical session. On the displayed historical session details page, you can view resource session information, system session information, O&M operation records, file transmission records, and collaborative session records.
Figure 3 Historical session details
Exporting Historical Session Records
Auditors can export historical session recordings and audit historical sessions offline.
- In the navigation pane on the left, choose to go to the historical session list page. Figure 4 Historical session list
- (Optional) Select one or more historical session records. If no session record is selected, all historical session recordings are exported by default.
- Click
in the upper right corner and create a download task. - Click Go to Download Center to go to the download task list.
- When the packing progress of the download task reaches 100%, click Download in the Operation column to download the file to a local PC. Once the file is downloaded, open it locally to check the exported historical session recordings. Figure 5 Download
