Logging In to Hosts in Batches for O&M
You can batch log in to host resources through your bastion host for operations, including file transfer, file management, and command presetting. A bastion host can log all activities performed on a host resource. The logs can be used for audits.
This section describes how to log in to hosts in batches using a web browser.
- Batch login is unavailable for hosts configured with the FTP, SFTP, DB2, MySQL, Oracle, SQL Server, or SCP protocol.
- Manual login and two-person approval accounts cannot be used for batch logging.
- The cooperation session function is unavailable for hosts logged in through batch logging.
- You have the management permissions for the Host Operation module.
- You have obtained the access permissions for the resources.
- Log in to your bastion host.
- Choose Operation > Host Operations to go to the Host Operations page.
- Select multiple resources and click Batch Logon.
Figure 1 Batch logon session windows
- Switch over session windows.
Click the resource name in the batch logon list to switch to the corresponding session window.
- For details about the operations in the session window, see the following description.
- Upload files to or download files from the host or host net disk. For details, see File Transfer.
- In the file management area, manage files or folders on the host or host net disk. For details, see Using a Web Browser for Logging In.
