Updated on 2025-10-28 GMT+08:00
Managing Application Resources
You can edit the information about the application resources managed in your bastion host. You can edit basic information, resource accounts associated with the resources, and authorized login users. You can also add resource accounts and labels for application resources.
Viewing the Application Resource List
  1. Log in to your bastion host.
  2. Choose Resources > Application > Application. On the application list page, you can view all managed application resources.
Editing Basic Application Resource Information
  1. Click the name of the target application resource or Manage in the Operation column. The application resource details page is displayed.
  2. In the Basic Info area, view basic information. Click Edit on the right. In the displayed dialog box, edit basic information about the application resource. For details about the parameters, see Table 3.
  3. Confirm the information and click OK.
Managing Resource Accounts for an Application Resource
  2. In the Account area, view the accounts associated with the current application resource.
    • Click the name of the target resource account or View in the Operation column to view the detailed information about the resource account.
    • Click Remove in the Operation column of the target resource account to disassociate the resource account from the current application resource.
  3. Click Add on the right. In the dialog box displayed, enter the account information to add an account for the current application resource. For details about the parameters, see Table 4.
  4. Confirm the information and click OK.
Managing Authorized Users for an Application Resource
  2. In the Account area, view the login users associated with the current application resource.
Batch Editing Operation Options for Application Resources
  1. In the application list, select target application resources and choose More > Edit Option in the lower left corner of the list.
  2. In the dialog box displayed, select the options you want to edit.
    Batch editing actions cannot be rolled back. Exercise caution when performing this operation.
Editing the Department for an Application Resource
  1. In the application list, select the target application resources and choose More > Edit Dept in the lower left corner of the list.
  2. In the dialog box displayed, select the department as needed.
Batch Adding Resource Accounts for Application Resources
  1. In the application list, select the target application resources and choose More > Add Account in the lower left corner of the list.
  2. In the dialog box displayed, enter the account information. For details about the parameters, see Table 4.
Deleting an Application Resource
  1. In the application list, locate the target application resource and choose More > Delete in the Operation column.
  2. In the dialog box displayed, confirm the information and click OK.
    No operations can be performed on deleted resources. Exercise caution when performing this operation.
Exporting the Application Resource List
  1. On the Application page, select the application resources to be exported.
    If no resources are selected, information about all resources is exported by default.
  2. Click in the upper right corner. Confirm the export in the displayed dialog box.
    • Set an encryption password to encrypt the exported file.
    • Enter your password.
    • Select the CSV or Excel format.
  3. Click OK. After the task is created, click Go to Download Center. If the export progress reaches 100%, click Download in the Operation column. Then you can view the exported application resource information in the downloaded file.
