Managing Application Servers
You can use the bastion host instance to edit, delete, and export application servers to ensure that the application server information is updated in a timely manner.
Editing Application Server Information
- Log in to your bastion host.
- Choose Resource > Application > AppServer.
- Click the name of the target application server or Manage in the Operation column. The application server details page is displayed.
- In the Basic Info area, view the details about the application server and click Edit on the right.
- In the displayed dialog box, edit the basic information about the application server. For details about the parameters, see Table 1.
The OS type for application servers cannot be edited.
- Confirm the information and click OK.
Deleting One or More Application Servers
- Click the name of the target application server or Delete in the Operation column. In the dialog box displayed, confirm the information and click OK.
If you delete an application server, resources that are using the server will be disconnected from the bastion host immediately. No more operations can be performed for the resources. Exercise caution when performing this operation.
Batch Exporting Application Servers
- Choose
and select the application server resources to be exported.
If no application servers are selected, information about all application servers is exported by default.
- Click
in the upper right corner. Confirm the export in the displayed dialog box.
- Set an encryption password to encrypt the exported file.
- Enter your password.
- Select the CSV or Excel format.
- Click OK. After the task is created, click Go to Download Center. If the export progress reaches 100%, click Download in the Operation column. Then you can view the exported application server resource information in the downloaded file.
Changing the Department an Application Server Belongs To
- Select all target application servers and choose OK.
in the lower left corner of the list. In the dialog box displayed, select the target department, confirm the information, and click
The department for all the selected servers will be edited. The batch operation cannot be canceled. Exercise caution when performing this operation.
