Overview
You can set labels to identify and group host and application resources managed in a bastion host. In this way, you can identify all resources related to a managed host or application resource.
After a label is added to a host or application, all managed resources related to the host or application will be labeled. In this way, you can search for resources by label. A host or application can have a maximum of 10 labels.
Each managed resource, such as ECSs and RDS instances, is tagged with two labels. Label 1 is identified by team, and Label 2 and Label 3 are identified by project. You can search for resources by label.
Navigation Path |
Operation |
Dashboard > Recently Logged Host |
Search for resources. |
Dashboard > Recently Logged Application |
Dashboard > My Hosts |
Dashboard > My APPs |
Resource > Host |
Add, delete, or edit labels and search for resources by label. |
Resource > Application |
Operation > Host Operations. |
Add or delete labels and search for resources by label. |
Operation > App Operations |
