Managing Host or Database Resources
You can view and edit the basic information, login users, resource accounts, O&M tasks for a specific host managed in your bastion host. You can also view and edit the basic information about proxy servers on the bastion host.
Viewing the Host or Database Resource List
- Log in to your bastion host.
- Choose Resource > Host in the navigation pane on the left.
- Click the Host List tab. On the page displayed, you can perform a quick search or an advanced search to search for the target resource.
- Quick search: Enter a keyword in the search box and search for a user by login name or username.
- Advanced search: Click Advanced next to text box and enter keywords in the corresponding attribute search boxes to search for resources.
Editing Basic Information About a Resource
- Click the name of the target resource or Manage in the Operation column. The resource details page is displayed.
- In the Basic Info area, view all information about the current resource.
- Click Edit on the right of the area. In the displayed dialog box, edit the basic information about the current resource. For details about the parameters, see Table 1.
- Edit the content as needed, confirm the information, and click OK.
Edit or Add Resource Accounts for a Resource
A resource account verifies your identity when you log in to a resource managed in your bastion host for O&M. You can associate multiple resource accounts with a resource.
Method 1: Edit and add resource accounts.
- In the Account area, view the accounts associated with the current resource.
- Click Add on the right of the area. In the displayed dialog box, create a resource account. For details about the parameters, see Table 1.
- Confirm the information and click OK. The resource account is created and associated with the current resource. Return to the resource account list to view the new resource account. If the new resource account is listed, the resource account has been added.
- Locate the target resource account and click Remove in the Operation column to disassociate the target resource account from the current resource. The removed resource account will not be deleted.
- Click the resource account name or View in the Operation column. On the displayed account details page, edit the basic information, joined group, and authorized users of the account.
Method 2: Add resource accounts only.
- Locate the target resource and click in the Operation column to add a resource account.
- In the displayed dialog box, create a resource account for the current resource. For details about the parameters, see Table 1.
Editing the Authorized Login User of a Resource
The login user associated with a resource can view the resource details after logging in to the bastion host instance. Unauthorized users cannot view the resource details.
- In the Authorized User area, view the authorized login users of the current resource.
- Click the username to view the details about the user. You can also edit the login restriction and user group of the user. For details, see User Management.
Editing an Operation Task for a Resource
- In the OPS Task area, view the operation task details of the current resource.
Deleting a Managed Resource
Locate the target managed resource and choose in the Operation column to delete the resource.
After a resource is deleted, all data of the resource is cleared. The resource account associated with the resource is cleared. The data of the resource account associated with the policy and ticket is also deleted.
Batch Editing OS Type for Resources
The OS type of a resource is identified by label. You can use labels to filter resources of the same OS type and manage them or edit their settings centrally.
You can also quickly locate the resources of the same OS type and change their passwords together.
- On the Host List tab, select all target resources and choose in the lower left corner of the list.
Make sure only the same type of resource is selected. Once the modification is complete, the OS type of all the selected resources will be changed.
- In the dialog box displayed, select the OS type as needed.
Batch Editing Resource Encoding
You can switch the encoding format of resources managed by your bastion host. In this way, you can easily view resources in different encoding formats.
- In the dialog box displayed, select an encoding format as needed.
Currently, only UTF-8, Big5, and GB 18030 are supported.
Batch Editing Operation Options for Hosts
The operation options include the actions and audits a user can perform during resource operation.
Make sure the right resources are selected. Once the modification is complete, the supported operation options will be changed for all the selected resources.
- In the dialog box displayed, select operation options as needed.
Options you can select: File Manage, X11 forward, Uplink Clipboard, Downlink Clipboard, and Keyboard Audit.
Batch Editing the Connection Mode
You can batch edit the connection mode of host resources. Your bastion host will connect to target hosts using the connection mode you select.
Make sure the right resources are selected. Once the modification is complete, the connection type will be changed for all the selected resources.
- In the dialog box displayed, select a connection mode as needed.
Currently, the direct connection and proxy modes are supported. If you select the proxy mode, you need to select a proxy server. If no proxy servers are available, create a proxy server by referring to Managing Proxy Servers.
Batch Editing Departments for Resources
Make sure the right resources are selected. Once the modification is complete, the department for all the selected resources will be changed accordingly.
- In the dialog box displayed, select a department as needed.
Batch Adding Resource Accounts
You can add one resource account for multiple resources at a time. In doing this, the resource account will be associated with all selected resources.
Make sure the right resources are selected. Once the task is finished, the same account will be added for all the selected resources.
- In the displayed dialog box, enter the information about the resource account you want to add. For details about the parameters, see the corresponding parameters in Table 1.
Batch Exporting Host Resources
- On the Host page, select the host resources to be exported.
If no resources are selected, information about all resources is exported by default.
- Click
in the upper right corner. Confirm the export in the displayed dialog box.
- Set an encryption password to encrypt the exported file.
- Enter your password.
- Select the CSV or Excel format.
- Click OK. After the task is created, click Go to Download Center. If the export progress reaches 100%, click Download in the Operation column. Then you can view the exported host resource information in the downloaded file.
