Help Center/
Cloud Bastion Host/
User Guide/
User and Resource Account/
User Group Management/
Editing the Members of a User Group
Updated on 2025-09-29 GMT+08:00
This section describes how to add members to or remove members from a user group.
- If you have the permissions for the User module, you can view user group details. However, for the user groups in the superior department, you can view only the user list of the user group.
- If you have the permissions for the User module, you can remove a user of a superior department out of a user group. However, as a user in a lower-level department, you have no permissions to add those removed users back to the user group.
You have the operation permissions for the User module.
- Log in to your bastion host.
- Choose User > User Group in the navigation pane.
- In the Operation column of the user group you want to edit, click Member.
Figure 1 Editing the members of a user group
- In the displayed dialog box, select Add By User or Add By Department.
- After selecting a user or department, click OK.
Parent topic: User Group Management
