Using a Web Browser to Log In to Your Bastion Host
You can use mainstream browsers to log in to your bastion host for system management and resource O&M. Web browsers are recommended for system administrator admin or other administrators to manage the system and audit authorization.
- First-time login users are required to bind a mobile number for password resetting.
- If you log in to a bastion host through the service console, you can select Local Login, IAM Login (available in V3.3.44.0 or later), or Admin Login (available in V3.3.52.1 or later, but not supported by Kunpeng bastion hosts). If you select IAM Login or Admin Login, no password is required.
An EIP has been bound to your bastion host.
- Enter the IP address of your bastion host in the address box of your browser to access the login page.
URL: https://EIP of your bastion host, for example, https://10.10.10.10.
Use supported browsers to access your bastion host. In an incompatible browser, the login verification message may fail to be sent to you, or exceptions may occur after you log in. For recommended browsers, see Restrictions on Using CBH.
- Select a login method on the login page.
- Enter credentials required by the login method you chose.
- Using Static Passwords for Login Authentication
- Using SMS Messages for Login Authentication
- Using an Email Address for Login Authentication
- Using Mobile OTPs for Login Authentication
- Using a USB Key for Login Authentication
- Using an OTP Token for Login Authentication
- Using Azure AD for Login Authentication
- JDZY Authentication Login
- Select Password.
- Enter the username and password of your account.
- Click Login.
Before you start, ensure that your mobile number can receive SMS messages.
- Select SMS.
- Enter the username and password of your bastion host account.
- Click Send code and enter the 6-digit OTP token in the received SMS message.
- Click Login.
- Select Email.
- Obtain a verification code and enter the verification code.
- Click Login.
Before you start, ensure that the time on your mobile phone is the same as that in your bastion host, accurate to seconds.
The mobile phone token applet for your bastion host is stored in the applet cache. The applet cache may be cleared mistakenly in the background.
You can save the QR code image when applying for a mobile phone token. If the preceding situation occurs, scan the QR code again.
- Select OTP.
- Start the token client on your mobile phone, obtain the 6-digit OTP, and enter it in the OTP text box.
- Click Login.
- Select USBKey.
- Insert your USB key. The bastion host automatically identifies the USB key.
- Enter the PIN code displayed on your USB key.
- Click Login.
- Select OTP token.
- Obtain the 6-digit OTP from the issued hardware token and enter it in the OTP token text box.
- Click Login.
This login method is available only after remote Azure AD authentication is configured.
- Click the Azure AD login link to go to the Microsoft Azure login page.
- Enter the username and password of your Microsoft Azure account as prompted.
Your login name must contain the email address suffix, for example, zhang@example.com.
- Click Log In. After the verification is successful, you can log in to the system.
This login option will not be displayed unless you configure JDZY authentication. For details, see Configuring JDZY Remote Authentication.
- Click JDZY Authentication Login. The JDZY authentication login page is displayed.
- Enter your username and password.
