Updated on 2025-09-29 GMT+08:00
Logging In to an Instance
You can log in to a bastion host remotely, using a browser, or using a client.
During remote logins, you can select local, IAM, or admin login mode. In local or IAM login mode, use the accounts as required. In admin login mode, you can log in to a bastion host as user admin without entering passwords.
Accounts or keys are required for local logins, client logins, and browser logins.
If you have logged in to your bastion host using the current browser, you need to log out of the current account before logging in to the instance using another account.
Port Requirements
To use a bastion host for resource management, ensure that the communication between the bastion host and the managed resources is enabled. Before you start, check whether your network ACL configuration allows access to the bastion host and configure the security group for the bastion host by referring to Table 1.
  • During cross-version upgrade, ports 80, 8080, 443, and 2222 are automatically enabled for the instance. If you do not need to use these ports, disable them immediately after the upgrade.
  • During cross-version upgrade, ports 22, 31036, 31679, and 31873 are automatically enabled for the instance. After the upgrade, keep port 31679 enabled and disable other ports immediately if you do not need to use them.
Table 1 Inbound and outbound rule configuration reference
Scenario Description
Direction
Protocol/Application
Port
Accessing a bastion host through a web browser (HTTP and HTTPS)
  • If HTTPS is used, configure port 443 only.
  • HTTP automatically redirects requests to HTTPS. If HTTP is used, configure both ports 80 and 443. Otherwise, the automatic redirection will not take effect.
Inbound
TCP
Ports 80 and 443
Accessing a bastion host through Microsoft Terminal Services Client (MSTSC)
Inbound
TCP
53389
Accessing a bastion host through an SSH client
Inbound
TCP
2222
Accessing a bastion host through an FTP client
Inbound
TCP
2121 and 20000 to 21000
Accessing a bastion host through an SFTP client
Inbound
TCP
2222
Remotely accessing Linux cloud servers managed by a bastion host over SSH clients
Outbound
TCP
22
Remotely accessing Windows cloud servers managed by a bastion host over the RDP protocol
Outbound
TCP
3389
Accessing Oracle databases through a bastion host
Inbound
TCP
1521
Outbound
TCP
1521
Accessing MySQL databases through a bastion host
Inbound
TCP
33306
Outbound
TCP
3306
Accessing SQL Server databases through a bastion host
Inbound
TCP
1433
Outbound
TCP
1433
Accessing DB databases through a bastion host
Inbound
TCP
50000
Outbound
TCP
50000
Accessing GaussDB databases through a bastion host
Inbound
TCP
18000
Outbound
TCP
8000 and 18000
License servers
Outbound
TCP
9443
Huawei Cloud services
Outbound
TCP
443
Accessing a bastion host system through an SSH client in the same security group
Outbound
TCP
2222
SMS service
Outbound
TCP
10743 and 443
Domain name resolution service
Outbound
UDP
53
Accessing PGSQL databases through a bastion host
Inbound
TCP
15432
Outbound
TCP
5432
Accessing DM databases through a bastion host
Inbound
TCP
15236
Outbound
TCP
5236
Accessing Redis databases through a bastion host
Inbound
TCP
16379
Outbound
TCP
6379
Accessing databases through an SSH tunnel
Inbound
TCP
62222
Logon Type
Different login methods require different credentials. If multifactor verification is enabled, the static password login method becomes invalid.
Table 2 Login method description
Logon Type
Login Description
Password
Enter the username and password of your bastion host.
Mobile SMS Authentication
Enter the username and password of your bastion host, click Send Code, and enter the SMS verification code you will receive.
Mobile OTP
Enter the username and password first, and then enter the mobile one-time password (OTP).
USBKey
Insert your USB key into your terminal device, select the issued USB key, and enter the corresponding personal identification number (PIN).
One-time Passwords (OTPs)
Enter the username and password first, and then enter the verification code displayed on your OTP token device.
Email
Enter the username, password, and email verification code. The email verification code is valid for 120 seconds.
Verification Type
You can use remote Active Directory (AD), Remote Authentication Dial In User Service (RADIUS), Lightweight Directory Access Protocol (LDAP), Security Assertion Markup Language (SAML), and Azure AD authentication methods. You can use existing user passwords on any of those remote servers for identity verification.
Table 3 Authentication methods
Verification Type
Authentication Description
Local Authentication
Static passwords configured for the system are used for identity verification.
  • Multifactor verification can be configured for users authenticated by static password.
  • You can reset or change the static passwords. If you forgot this password, you can find it back through email.
AD domain authentication
The passwords of users on the AD server are used for identity verification.
  • Passwords cannot be changed through the bastion host.
RADIUS Authentication
The passwords of users on the RADIUS server are used for identity verification.
LDAP Authentication
The passwords of users on the LDAP server are used for identity verification.
The passwords of Microsoft accounts are used for identity verification.
The login page is redirected to the Microsoft Azure login page for you to provide credentials.
  • Multifactor verification cannot be configured for users authenticated by the Azure AD server.
SAML authentication
The passwords of users on the SAML server are used for identity verification.
