- Billing
- Getting Started
User Guide
- Overview
- Permissions Management
- Environment Management
- Application Management
- Component Management
- Instance Management
- Component Configurations
- Component O&M
- System Settings
- Key Operations Recorded by CTS
Best Practices
- CAE Best Practices
- Using CAE to Host Nginx Static File Servers
- Interconnecting GitLab with Jenkins for Automatic Build and Deployment on CAE
- Deploying Components Based on the Dependency Sequence Using the Jenkins Pipeline
- Deploying Spring Cloud Applications to CAE to Automatically Connect to the Nacos Engine
- Graceful Startup of a Spring Cloud Application
- Health Check
- Lifecycle Management
- Sending Event Alarms to WeCom
Connecting to the CodeArts Pipeline to Automatically Upgrade CAE Components
- Overview
- Upgrading a CAE Component After Uploading a Software Package Built Using the Pipeline to a CodeArts Release Repo
- Upgrading a CAE Component After Uploading a Software Package Built Using the Pipeline to the OBS Bucket
- Upgrading a CAE Component After Uploading an Image Built Using the Pipeline to the SWR Image Repository
- Configuring PromQL to Implement Custom Auto Scaling
- Configuring the Interconnection Between CAE and DEW to Help Applications Obtain Encrypted Secrets from DEW
- Deploying ASP.NET Core Applications to CAE
- Connecting the Network Through Enterprise Routes
- API Reference
- Component Management FAQs
Component Configuration FAQs
- Is Manual Scaling Still Effective When a Scaling Policy Is Configured?
- Can Components Be Scaled Without a Scaling Policy?
- Why Is My Instance Abnormal After Cloud Storage Is Configured?
- What Do I Do If a Component Becomes Not Ready?
- How Does CAE Support Dark Launch?
- How Do I Provide Prometheus Metrics for a Java Application?
- System Configuration FAQs
- Service Resources FAQs
Component Overview
An application component implements a service feature of an application. It is in the form of code or software packages and can be deployed independently.
After creating an application on CAE, you can create components in the application.
Component Description
Table 1 lists the languages and runtime systems supported by CAE components.
Runtime System |
Component Source |
Java 8, Java 11, Java 17, Java 21 |
Source code repository, JAR package |
Tomcat 8, Tomcat 9 |
Source code repository, WAR package |
Node.js 8, Node.js 14, Node.js 16 |
Source code repository, ZIP package |
PHP 7, PHP 8 |
Docker |
Image package |
Python 3 |
.net core |
Source code repository |
Component Source
Component Source |
Description |
GitHub, GitCode, GitLab, and Bitbucket code can be identified. |
Image |
If you use a private image to create your containerized application, upload the private image to the image repository. The following upload modes are supported:
CAE container-based deployment does not support images of the Arm architecture. |
Software package |
