Restarting a BMS
You can restart BMSs on the console. Only BMSs in running state can be restarted.
   Restarting a BMS will interrupt your services. Exercise caution when performing this operation.
 - Under Computing, click Bare Metal Server.
The BMS console is displayed.
 - Locate the row that contains the target BMS, click More in the Operation column, and select Restart from the drop-down list. To restart multiple BMSs, select them and click Restart at the top of the BMS list.
 - In the displayed dialog box, click Yes.
   Parent topic: Managing BMSs
