On this page
Help Center/ Bare Metal Server/ User Guide/ Instance/ Creating a BMS/ Creating a BMS from a Private Image
If you want to create a BMS that has the same OS and applications as an existing BMS, you can create a private image using the existing BMS and then create a BMS using the private image. This frees you from repeatedly configuring BMSs and improves efficiency.
Background
You can create a private image using either of the following methods:
Create a BMS by following the instructions in Creating a Common BMS.
Note for setting the parameters:
  • Region: Select the region where the private image is located.
  • Flavor: OSs supported by different BMS flavors vary. For details, see OSs Supported by Different Types of BMSs. Select a flavor based on the private image OS.
  • Image: Select Private image or Shared image and select the required image from the drop-down list.
  • Disk: If the selected flavor supports quick provisioning, you are advised to increase System Disk by 2 GB or more.
