Managing Template Scenarios in Applications
A template scenario is a collection of service scenarios. Multiple templates can be created in a template scenario. The templates share the data structure. After a template scenario is created, it can be called in flows.
On the template scenario management page, you can view and manage template scenarios in applications.
- Log in to the Huawei Cloud Astro Zero console and click Access Homepage. The application development page is displayed.
- In the upper left corner of the page, click
and choose Environments > Environment Configuration. - Choose Maintenance from the main menu.
- In the navigation pane, choose Global Elements > Template Scenarios to view all template scenarios created under the account.
- Click
next to a template scenario to disable the template scenario.To enable a disabled template scenario again, click
. - After a template scenario is disabled, click
to delete the template scenario.
