Configuring an Archive Instance
Once a data archiving instance is configured, all associated archiving tasks will direct their data to this instance. Huawei Cloud Astro Zero facilitates the archiving process but does not offer storage for the archived data.
- Log in to the Huawei Cloud Astro Zero console and click Access Homepage. The application development page is displayed.
- In the upper left corner of the page, click
and choose Environments > Environment Configuration. - Choose Maintenance from the main menu.
- In the navigation pane, choose Global Elements > Data Archiving > Archive Instance Configuration.
- On the Archive Instance Configuration page, click New Archive Instance.
- Select an archive instance type, set connection parameters, and click Test and Save.
Table 1 Parameters for creating an SFTP archive instance Parameter
Host
IP address of the SFTP server.
Port
Port number of the SFTP server.
Value range: 22 to 65535
UserName
Username for accessing the SFTP server.
Password
Password for logging to an SFTP server.
Storage Root Directory
Root directory for access; all operations will include this path prefix.
Table 2 OBS/MINIO archive instance parameters Parameter
Access key
Access key ID of OBS/MINIO, which needs to be obtained in advance.
Key
Key of OBS/MINIO, which needs to be obtained in advance.
Terminal node
Endpoint, for example, obs.***.example.com. For MINIO, the internal minio endpoint of the platform is used. You do not need to set the endpoint.
Bucket Name
Bucket name. The name can contain only lowercase letters, digits, hyphens (-), and dots (.). Consecutive dots are not allowed. The name cannot start or end with a dot.
