Help Center/ Huawei Cloud Astro Zero/ User Guide (Low-Code)/ Managing Installed Applications/ Uninstalling Installed Applications
Updated on 2025-08-15 GMT+08:00
You can uninstall applications. After the software package is uninstalled, dependencies outside the application are unavailable. Exercise caution when performing this operation.
Uninstalling an Application
- Log in to the Huawei Cloud Astro Zero console and click Access Homepage. The application development page is displayed.
- Click
in the upper left corner of the page and choose Environments > Environment Configuration. - In the navigation pane, choose Application Management > Installation Management > Package Installation.
- In the software package list, click
next to the software package to be uninstalled. - Click Uninstall to confirm the operation. The application and all its dependent configuration items will be deleted. To delete only the application, see Viewing Installed Applications.Figure 1 Confirming software package uninstallation
- On the displayed page, click Uninstall.
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
