Help Center/ Huawei Cloud Astro Zero/ User Guide (Low-Code)/ Huawei Cloud Astro Zero Management Center/ Managing the Information Application Resources/ Managing Page Resources in Applications/ Managing Deactivated Assets
Updated on 2025-08-15 GMT+08:00
You can disable widgets, libraries, or bridges that are no longer used. After an asset is disabled, you can view, enable, or delete the asset here.
- Log in to the Huawei Cloud Astro Zero console and click Access Homepage. The application development page is displayed.
- In the upper left corner of the page, click
and choose Environments > Environment Configuration. - Choose Maintenance from the main menu.
- In the navigation pane, choose Global Elements > Page Assets > Deactivated Assets. You can view the deactivated widgets, libraries, and bridges.
- Click a deactivated asset. On the details page displayed, perform the following operations:
- Click Activate. In the dialog box that is displayed, click OK.
- Click Delete, enter the asset name, and click Confirm.
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
