Help Center/
Huawei Cloud Astro Zero/
User Guide (Low-Code)/
Managing Installed Applications/
Adding Portal Users for Applications Developed on Huawei Cloud Astro Zero/
Portal User Overview
Updated on 2025-08-15 GMT+08:00
Portal users are application users. This section describes portal users.
What Is a Portal User?
There are two types of users in Huawei Cloud Astro Zero: users and portal users.
- Users are developer accounts, managing applications and portal users. By default, the account that purchases the Huawei Cloud Astro Zero instance has all permissions. It is an administrator and can add other user accounts and configure required permissions for them.
- Portal users are the accounts for accessing and using service applications. You can manage these accounts, including creating, deleting, and editing them, in the service configuration center. Additionally, you can set permissions for each portal user.
Figure 1 User behavior
Portal Users' Capabilities
- Access applications and view navigation menus based on permissions.
- View the page layout of the application based on the permission.
- View, create, edit, and delete objects in the application based on permissions.
- View and edit object fields in the application based on the permission.
- Executes flows, scripts, and BPMs developed in applications based on permissions.
- Accesses public APIs customized in applications based on permissions.
