Updated on 2026-09-04 GMT+08:00
Monitoring Metrics
This section describes the monitoring metrics reported by AS to Cloud Eye and defines the namespace for the metrics. You can use Cloud Eye to query monitoring metrics and alarms of AS.
Namespace
SYS.AS
Items in Alarm Policies
You can monitor key metrics of AS. Then you can handle exceptions in a timely manner. For details about the items in an alarm policy, see the following table.
Items in an alarm policy for metrics
Item
Example
Metric
Specifies the name of an AS metric.
CPU Usage
Statistic
Specifies the metric value type. There are six types of values: Max., Mini., Avg., Raw data, Variance, and Sum.
  • Max. is the highest value observed during a rollup period.
  • Min. is the lowest value observed during a rollup period.
  • Avg. is the value calculated by averaging raw data during a rollup period.
  • Raw data indicates the metric data that is not processed or converted.
  • Variance indicates the difference between each data point in the original value and the average value within a rollup period.
  • Sum is the sum of raw data during a rollup period.
Raw data
Operator
Specifies the operator used to compare the metric value and the threshold.
Supported operators: >, >=, <, and <=
Threshold
Specifies the threshold of the metric value.
70
AS Metrics
Table 1 lists the AS metrics supported by Cloud Eye.
Table 1 AS metrics
Metric ID
Metric
Value Range
Unit
Conversion Rule
Monitored Object (Dimension)
Monitoring Interval (Raw Data)
cpu_util
CPU Usage
CPU usage of an AS group
Formula: Total CPU usage of all ECS instances in an AS group/Number of ECS instances in the AS group
≥0
N/A
instance_id
5 minutes
mem_util
Memory Usage
Memory usage of an AS group
Formula: Total memory usage of all ECS instances in an AS group/Number of ECS instances in the AS group
This metric is unavailable if the image has no VMTools installed.
≥0
N/A
instance_id
5 minutes
instance_num
Number of Instances
Number of available ECS instances in an AS group
Formula: Total number of ECS instances in Enabled state in the AS group
This metric is used by Cloud Eye to monitor AS groups and is not used to trigger alarm policies.
≥0
count
N/A
instance_id
5 minutes
network_incoming_bytes_rate_inband
Inband Incoming Rate
Number of incoming bytes per second on an ECS in an AS group
Formula: Total inband incoming rate of all ECS instances in an AS group/Number of ECS instances in the AS group
≥0
byte/s
1024 (IEC)
instance_id
5 minutes
network_outgoing_bytes_rate_inband
Inband Outgoing Rate
Number of outgoing bytes per second on an ECS in an AS group
Formula: Total inband outgoing rate of all ECS instances in an AS group/Number of ECS instances in the AS group
≥0
byte/s
1024 (IEC)
instance_id
5 minutes
disk_read_bytes_rate
Disks Read Rate
Number of bytes read from an AS group per second
Formula: Total disk read rate of all ECS instances in an AS group/Number of ECS instances in the AS group
≥0
byte/s
1024 (IEC)
instance_id
5 minutes
disk_write_bytes_rate
Disks Write Rate
Number of bytes written to an AS group per second
Formula: Total disk write rate of all ECS instances in an AS group/Number of ECS instances in the AS group
≥0
byte/s
1024 (IEC)
instance_id
5 minutes
disk_read_requests_rate
Disks Read Requests
Number of disk read requests sent to an AS group per second
Formula: Total number of disk read requests sent to all ECS instances in an AS group/Number of ECS instances in the AS group
≥0
r/s
N/A
instance_id
5 minutes
disk_write_requests_rate
Disks Write Requests
Number of disk write requests sent to an AS group per second
Formula: Total number of disk write requests sent to all ECS instances in an AS group/Number of ECS instances in the AS group
≥0
r/s
N/A
instance_id
5 minutes
cpu_usage
(Agent) CPU Usage
Agent CPU usage of an AS group
Formula: Total (Agent) CPU usage of all ECS instances in an AS group/Number of ECS instances in the AS group
0-100
N/A
instance_id
1 minute
mem_usedPercent
(Agent) Memory Usage
(Agent) Memory usage of an AS group
Formula: Total (Agent) memory usage of all ECS instances in an AS group/Number of ECS instances in the AS group
0-100
N/A
instance_id
1 minute
load_average1
(Agent) 1-Minute Load Average
Average CPU load of all ECSs in an AS group in the last 1 minute
≥0
N/A
instance_id
1 minute
load_average5
(Agent) 5-Minute Load Average
Average CPU load of all ECSs in an AS group in the last 5 minutes
≥0
N/A
instance_id
1 minute
load_average15
(Agent) 15-Minute Load Average
Average CPU load of all ECSs in an AS group in the last 15 minutes
≥0
N/A
instance_id
1 minute
gpu_usage_gpu
(Agent) GPU Usage
(Agent) GPU usage of an AS group
Formula: Total (Agent) GPU usage of all ECS instances in an AS group/Number of ECS instances in the AS group
0-100
N/A
instance_id
1 minute
gpu_usage_mem
(Agent) GPU Memory Usage
(Agent) GPU memory usage of an AS group
Formula: Total (Agent) GPU memory usage of all ECS instances in an AS group/Number of ECS instances in the AS group
0-100
N/A
instance_id
1 minute
  • The monitoring metrics with and without the Agent installed are different. The monitoring metrics vary depending on the OS. Some OSs require the Agent to collect specific metrics. In this case, you need to select the metrics marked with Agent, for example, (Agent) Memory Usage, as the trigger condition.
  • Before using Agent monitoring metrics, ensure that the Agent has been installed on the instances in the AS group. For details, see How Do I Install the Agent on Instances in an AS Group to Use Agent Monitoring Metrics?
  • For details about whether your OS supports the Memory Usage, Inband Outgoing Rate, and Inband Incoming Rate metrics, see Basic ECS Metrics.
Dimension
Key
Value
instance_id
AS group ID
You can obtain the value by referring to Querying Instances in an AS Group.
