Help Center/ Auto Scaling/ User Guide/ Instance Scaling/ AS Configurations/ Deleting an AS Configuration
Updated on 2026-01-06 GMT+08:00
When you no longer need an AS configuration, you can delete it as long as the AS configuration is not used by an AS group. You can delete a single AS configuration or delete them in batches.
- Log in to the AS console.
- Click the AS Configurations tab page, locate the row containing the target AS configuration, and click Delete in the Operation column to delete this AS configuration. You can also select multiple AS configurations to be deleted and click Delete in the upper part of the AS configuration list to delete them all at once.
Parent topic: AS Configurations
