Updated on 2026-09-04 GMT+08:00
Enabling an AS Group
You can enable an AS group to automatically scale capacity in or out.
After an AS group is enabled, its status changes to Enabled. AS monitors the AS policy and triggers a scaling action for AS groups only in Enabled state. After an AS group is enabled, AS triggers a scaling action to automatically add or remove ECS instances if the number of ECS instances in the AS group is different from the expected number of instances.
  • Only AS groups in the Disabled state can be enabled.
  • Only AS groups in the Abnormal state can be forcibly enabled. You can choose More > Forcibly Enable to enable an abnormal AS group. Forcibly enabling an AS group does not have adverse consequences.
  • After you create an AS group and add an AS configuration to an AS group, the AS group is automatically enabled.
  1. Log in to the AS console.
  2. Enable an AS group.
    You can enable an AS group using either of the following methods:
    • Locate the row that contains the target AS group and click Enable in the Operation column.
    • Click the name of the target AS group. In the upper right corner of the Overview page, click Enable.
  3. In the displayed dialog box, click OK.
Forcibly Enabling an AS Group
You can forcibly enable an AS group only when the AS group is in the Abnormal state. Forcibly enabling an AS group will not cause any adverse consequences.
  2. Forcibly enable an AS group.
    You can forcibly enable an AS group using either of the following methods:
    • Locate the row that contains the target AS group and choose More > Forcibly Enable in the Operation column.
    • Click the name of the target AS group. In the upper right corner of the Overview page, click Forcibly Enable.
