Checking the Basic Information About an Application, Sub-Application, Component, and Environment
- Log in to the APM console.
- Click
on the left and choose Application > Application Performance Management. - In the navigation pane, choose Application Monitoring > Metrics.
- Click an application in the tree on the left.
- In the right pane, click Application Info to check the basic information about the application.
Table 1 Basic information of the application Parameter
Application Name
Name of the application.
Display Name
Alias of the application.
Description of the application. Enter up to 1,000 characters.
Enterprise Project
Enterprise project name. It is displayed only when you have enabled the enterprise edition.
Creator
User who creates the application.
Created
Time when the application is created.
Default Application
Whether the application is the default one. If it is a default application, (Default) will be displayed next to its name in the Application column in the tree on the left.
Checking the Basic Information About a Sub-Application and Component
- Click a sub-application or component in the tree on the left. Sub-application Info or Component Info is displayed on the right.
Table 2 Basic information about the sub-application or component Parameter
Sub-Application/Component Name
Name of the sub-application or component.
Display Name
Alias of the sub-application or component.
Description of the sub-application or component. Enter up to 1,000 characters.
Creator
User who creates the sub-application or component.
Created
Time when the sub-application or component is created.
Environment and components are created when you connect an Agent. To monitor Java applications, see Connecting Agents.
Checking the Basic Information About an Environment
- In the tree on the left, click
next to the target environment. The instance monitoring page is displayed. - Click the Basic Info tab to check the basic information about the environment.
Table 3 Basic information about the environment Basic Attributes
Component
Component Name
Name of a component.
Created
Time when the component is created.
Creator
User who creates the component.
Environment
Environment Name
Name of an environment.
Environment Type
Type of the environment.
Tag Name
Environment tag. For details about how to manage tags, see Managing Tags.
Region
Region where the environment is located.
Creator
User who creates the environment.
Created
Time when the environment is created.
UUID
Component ID.
