Agent Download Addresses
- Only JDK 8, JDK 11, and JDK 17 are supported.
- In the JDK 8 environment, select a version not ended with -jdkxx. In other JDK environments, select a version ended with -jdkxx. If profiling is required, select a version ended with -profiler.
- For versions ended with -jdk17 or -jdk11, add -jdk17 or -jdk11 to the end of the Agent download path.
Example: If the download address for Agent 2.4.12 is https://apm2-javaagent***/apm2_javaagent/apm-javaagent-2.4.12.tar, the download address for Agent 2.4.12-jdk17 will be https://apm2-javaagent***/apm2_javaagent/apm-javaagent-2.4.12-jdk17.tar.
| Region | Latest Version | Earlier Versions | |||||
| CN-Hong Kong | sha256:f5b59a4a443dd179df2c24e92f4662660fe0405d62dba4d02121e5f4cf37c200 | sha256:8c28c24120951c04a937356e4a5610a18a1f8105199b71c0910c2a79b4b19a1b | sha256:3d9a24e42b75c8d184df31c93e9129a00472631a5fccf1f7bf9126732acdeae4 | sha256:fdb38728342b69f9ccdfe824975d82c1d03d51e33037ce3107c55f0a1cb50c7e | sha256:12a9d2b9aec31e41edce6c27391677f565805a8cc4efe9e0f3c89e9bfcd16eae | sha256:d9481030d4481f4c50fa86cee7d6918ea2577ff9fdae9f8457f8b8e48be2e625 | sha256:c752cc96fe09f62cb76daa9094eb4dfc936b0f865e7b35ca89a0d6f4b5aecd7e |
| AP-Singapore | sha256:f5b59a4a443dd179df2c24e92f4662660fe0405d62dba4d02121e5f4cf37c200 | sha256:8c28c24120951c04a937356e4a5610a18a1f8105199b71c0910c2a79b4b19a1b | sha256:3d9a24e42b75c8d184df31c93e9129a00472631a5fccf1f7bf9126732acdeae4 | sha256:fdb38728342b69f9ccdfe824975d82c1d03d51e33037ce3107c55f0a1cb50c7e | sha256:12a9d2b9aec31e41edce6c27391677f565805a8cc4efe9e0f3c89e9bfcd16eae | sha256:d9481030d4481f4c50fa86cee7d6918ea2577ff9fdae9f8457f8b8e48be2e625 | sha256:c752cc96fe09f62cb76daa9094eb4dfc936b0f865e7b35ca89a0d6f4b5aecd7e |
| CN North-Beijing4 | sha256:05ef1049965d99472996f0579d4928fc7e872f0d07c90a5b88ad02802374991a | sha256:8a502bdbb75660bcfff144e4622b753b247a515541ec39a1cb114ad5f7d24cca | sha256:f5b59a4a443dd179df2c24e92f4662660fe0405d62dba4d02121e5f4cf37c200 | sha256:8c28c24120951c04a937356e4a5610a18a1f8105199b71c0910c2a79b4b19a1b | sha256:3d9a24e42b75c8d184df31c93e9129a00472631a5fccf1f7bf9126732acdeae4 | sha256:fdb38728342b69f9ccdfe824975d82c1d03d51e33037ce3107c55f0a1cb50c7e | sha256:12a9d2b9aec31e41edce6c27391677f565805a8cc4efe9e0f3c89e9bfcd16eae |
| LA-Sao Paulo1 | sha256:73de7b49e148b102b74a6075c3d8b25e76f43d6144ec5aafe6ac190ab3c1ef0b | - | - | - | - | - | - |
| TR-Istanbul | sha256:8893e89cd3174879232704828027fd636471525d6e5772ff77e3313f79a4b6b5 | - | - | - | - | - | - |
| AF-Johannesburg | sha256:029c57990339f2a9de418b4d19e6f7349106a630b7eae559abc9d6d9ea8776d7 | - | - | - | - | - | - |
| AF-Cairo | sha256:37b155626f46f3a8b19772e3fd6597ece92bb255fdffa21e3e9e1467cc009392 | - | - | - | - | - | - |
| AP-Manila | sha256:37b155626f46f3a8b19772e3fd6597ece92bb255fdffa21e3e9e1467cc009392 | - | - | - | - | - | - |
| ME-Riyadh | sha256:37b155626f46f3a8b19772e3fd6597ece92bb255fdffa21e3e9e1467cc009392 | - | - | - | - | - | - |
