Updated on 2025-06-27 GMT+08:00
Usage Statistics
After Agents are connected, you can check Agent Statistics and Written Data Statistics on the Usage Statistics page.
Checking Agent Statistics
  2. Click on the left and choose Application > Application Performance Management.
  3. In the navigation pane, choose System Management > Usage Statistics. The Application Monitoring Usage Statistics page is displayed. By default, the Agent Statistics tab page is displayed. There are statistics about Huawei-developed Agents only.
    Agent Statistics: displays the total number of Agents, total number of Java Agents, total number of Node.js Agents, and historical Agent statistics.
    • Click and select a time range to display historical Agent statistics. Max.: 24 hours. Options: Yesterday, Today, and Custom.
    • Click to refresh historical Agent statistics.
