Updated on 2026-09-18 GMT+08:00
Baidu SDK Access
  • Before using the Baidu SDK, you need to register a Huawei Cloud Account and enable APM.
  • To ensure that Baidu logs can be reported, add the report address to the domain name list of the Baidu developer platform as a valid domain name.
Transport Protocol
HTTPS
Version Updates
Table 1 Version updates
Version
Update Description
2.0.7
Supported sampling rate settings.
2.0.5
Added the uid and tag fields and the setUid and setTag methods.
2.0.4
Fixed the issue that the SDK overwrites the function scope of the applet.
2.0.1
Added the README help document.
2.0.0
This is the first release of the applet SDK.
Configuring the Report Address
Add the APM report address https://apm-web.region.myhuaweicloud.com to the domain name list of the applet developer platform.
Currently, this function is supported in the AP-Singapore region only. The report address is https://apm-web.ap-southeast-3.myhuaweicloud.com.
  1. On the Web Monitoring page, click Connect Website.
  2. Select Baidu, select an application, enter a site name, and click Create Website.
  3. Install the SDK. Run the npm i apm-mini-sdk command in the root directory of the project to pull the SDK software package.
  4. Enable the SDK. The code will be automatically embedded in the applet. You can execute the code anywhere in the project (app.js is recommended). The SDK can be imported using a file or npm.
    • Integrating the SDK using npm
      1. Run the SDK installation command to install the SDK software package:
      2. Copy the code for tracking from the page to the app.js file.
        Table 2 Configuration parameters
        Mandatory
        Default Value
        appId
        Yes
        Website ID. Each site has its own app ID.
        apiRepo
        No
        true
        Auto API reporting.
        Reports API call details and success rate.
        thirdApi
        No
        true
        Third-party API reporting.
        Reports third-party API information.
        hashMode
        No
        true
        Auto hash mode parsing.
        Processes the content following # as a part of a URL. If this option is disabled, # is regarded as an anchor.
        JsErrorClear
        No
        true
        JS error tracing.
        Listens on and reports all JS errors. This will change the service paths displayed on your browser.
        smartJsErr
        No
        true
        JS errors mitigation.
        Stops reporting a JS error after 100 times.
        webResource
        No
        false
        Page resource reporting.
        Collects loading performance. Only WeChat can collect First Paint (FP) information. Other mini programs do not support page resource reporting. If required, use the custom reporting function.
        traceType
        No
        apm
        Open tracing.
        Tracing: Traces the frontend and backend using OpenTelemetry. If this option is disabled, APM tracing will be used instead. To view the tracing effect, choose API Requests, go to the URL details page, and click Analyze.
        UID
        No
        Custom ID (string), which is added in version 1.0.46.
        tag
        No
        Custom tag (string), which is added in version 1.0.46.
        sampleRate
        No
        Sampling rate. Range: 0–1. For example, if this parameter is set to 0.5, the sampling rate is 50%. This parameter can be configured in SDK 2.0.7 or later.
  5. (Optional) Configure custom statistics reporting.
    Method
    agent.log(key: String, value: String)
    key: event name (string). Max.: 2,048 characters.
    value: event content. Valid JSON objects such as String, Array, HashMap, and Number are supported. Max.: 30,720 characters.
  6. (Optional) Dynamically set the UID.
    Method
    agent.setUid(uid: String)
    uid (string): max. 2,048 characters.
  7. (Optional) Dynamically set the tag.
    Method
    agent.setTag(tag: String)
    tag (string): max. 2,048 characters.
Data Reporting Policy
  1. Basic user data and custom statistics are reported immediately when a user accesses the page.
  2. Page performance data is triggered to report after the page is loaded.
  3. Other types of data (such as API data and JS error data) are reported every minute.
