Updated on 2025-11-18 GMT+08:00
Session Tracing
APM supports session tracing. This function enables full-link tracing based on the user name or ID. The behavior of a user can be reproduced to locate faults. Session tracing includes access, performance, API, JS error, behavior, and custom tracing.
Viewing Session Tracing
  1. Log in to the APM console.
  2. Click on the left and choose Management & Governance > Application Performance Management.
  3. In the navigation pane, choose Web Monitoring > Session Tracing. Select a site from the Site drop-down list. By default, the access tracing details of the site are displayed.
    1. In the upper right corner of the Session Tracing page, select a time range. Default: Last 20 minutes.
      Options: Last 20 minutes, Last hour, Last 3 hours, Last 6 hours, Last day, Today, Yesterday, Last week, Last month, or Custom.
    2. Click the search box and select criteria from the drop-down list to search. Click to view the session tracing information that meets the search criteria at the site.
    3. Click in the upper right corner of the list to export information. A maximum of 200 records can be exported.
Access Tracing
  1. In the navigation pane, choose Web Monitoring > Session Tracing. Select a site from the Site drop-down list. By default, the access tracing details of the site are displayed.
    • Click in the upper right corner of the access tracing list and select the target metric data.
    • By default, the access tracing list is sorted by Start Time in descending order.
    Table 1 Access tracing parameters
    Session ID
    Unique ID for a user to access a server or web page.
    Page URL
    URL of the accessed page.
    Start Time
    Time when the session starts.
    Client IP Address
    IP address of the client.
    UID
    User ID.
    Tag
    User-defined tag, which can be used as a keyword to search.
    Views (PV)
    Page view (PV), which is the number of times a page is opened or refreshed.
  2. Click a session ID in the Session ID column to view the user track details.
    • Metrics include Page Loads, API Requests, JS Errors, Visits, Clicks, and Custom Statistics.
    • User track details include All, Page Loads, API Requests, JS Errors, Clicks, Visits, and Custom Statistics.
      Click All to display all user track details of the session ID. A maximum of 200 tracks can be displayed.
      Click other tabs such as Page Loads to display the user track details of the session ID on the corresponding tab. For example, if you click the Page Loads tab, the user track details of all page loads under the session ID are displayed.
      You can collapse and expand user track details.
      Table 2 Parameters of user track details
      Type
      Page Loads
      Page URL
      Request Source
      Source of the request.
      Load Time
      Page load time.
      First Contentful Paint (FCP)
      Duration from the time when you open a website to the time when the content on the home page of the browser has been rendered.
      First Paint (FP)
      Duration from the time when you click a link or enter a URL to the time when the browser starts to display content.
      Time to Interactive (TTI)
      Duration from the time when a page starts to be loaded to the time when main resources are rendered and a response is made.
      API Requests
      Page URL
      Device ID
      ID of the device.
      API Address
      API address.
      Request Method
      The request method can be GET, POST, PUT, DELETE, or OPTION.
      Status Code
      Status code.
      JS Errors
      Error Occurred
      Address where the JS error occurred.
      Device ID
      ID of the device.
      Error Cause
      Cause of the JS error.
      Clicks
      Page URL
      Device ID
      ID of the device.
      X-axis Position
      X-axis position of the browser coordinate.
      Y-axis Position
      Y-axis position of the browser coordinate.
      Operation
      Options: chick and dbclick.
      Visits
      Access Address
      Client IP Address
      Client IP address.
      Client System
      Client OS type.
      Browser
      Browser type, for example, Chrome, Internet Explorer, or Firefox.
      Custom Statistics
      Page URL
      URL of the page to be reported.
      Event Name
      Name of an event.
      Event Value
      Event value. For details, see Custom Statistics.
Performance Tracing
  1. In the navigation pane, choose Web Monitoring > Session Tracing. Select a site from the Site drop-down list. Click Performance to switch to the performance tracing details of the site.
    Click in the upper right corner of the performance tracing list and select the target metric data.
    By default, the performance tracing list is sorted by Load Times in descending order.
    Table 3 Performance tracing parameters
    Session ID
    Page URL
    Client IP Address
    UID
    User ID.
    Tag
    Load Times
    Total number of times pages were loaded.
    Avg. Load Time
    Average page load time.
    Avg. First Contentful Paint (FCP)
    Average first contentful paint time.
    Avg. First Paint (FP)
    Average first paint time.
    Avg. Time to Interactive
    Average interaction time.
  2. Click a session ID in the Session ID column to view the user track details. For details, see 2.
API Tracing
  1. In the navigation pane, choose Web Monitoring > Session Tracing. Select a site from the Site drop-down list. Click APIs to switch to the API tracing details of the site.
    Click in the upper right corner of the API tracing list and select the target metric data.
    By default, the API tracing list is sorted by Load Times in descending order.
    Table 4 API tracing parameters
    Session ID
    Page URL
    Client IP Address
    UID
    User ID.
    Tag
    Load Times
    Avg. Load Time
    Slow Requests
    Number of slow API requests.
    Slow Request Rate
    Slow API request rate.
    Failed Requests
    Number of failed requests.
    Failed Request Rate
    Failed API request rate.
JS Error Tracing
  1. In the navigation pane, choose Web Monitoring > Session Tracing. Select a site from the Site drop-down list. Click JS Error Tracing to switch to the JS error tracing details of the site.
    Click in the upper right corner of the JS error tracing list and select the target metric data.
    By default, the JS error tracing list is sorted by Load Times in descending order.
    Table 5 JS error tracing parameters
    Session ID
    Page URL
    End Time
    Time when the last error was reported.
    Client IP Address
    UID
    User ID.
    Tag
    Load Times
    Views (PV)
    UV
    Number of visitors who access the website. If a user accesses the site multiple times in a day, only one UV will be counted.
Behavior Tracing
  1. In the navigation pane, choose Web Monitoring > Session Tracing. Select a site from the Site drop-down list. Click Behavior to switch to the behavior tracing details of the site.
    Click in the upper right corner of the behavior tracing list and select the target metric data.
    By default, the behavior tracing list is sorted by Start Time in descending order.
    Table 6 Behavior tracing parameters
    Session ID
    Page URL
    Start Time
    Time when the first operation is performed.
    Client IP Address
    UID
    User ID.
    Tag
    Load Times
    Views (PV)
Custom Tracing
  1. In the navigation pane, choose Web Monitoring > Session Tracing. Select a site from the Site drop-down list. Click Custom to switch to the custom tracing details of the site.
    Click in the upper right corner of the custom tracing list and select the target metric data.
    By default, the custom tracing list is sorted by Load Times in descending order.
    Table 7 Custom tracing parameters
    Session ID
    Page URL
    End Time
    Last report time.
    Client IP Address
    UID
    User ID.
    Tag
    Load Times
    Views (PV)
