Help Center/ Application Performance Management/ User Guide(2.0)/ Performance Monitoring/ Monitoring Component Performance Metrics/ Viewing the Message Queue Monitoring Item of a Component
Updated on 2026-09-18 GMT+08:00
This type of monitoring item monitors message queues, including KafkaProducer. This section focuses on KafkaProducer monitoring.
- Log in to the APM console.
- Click
on the left and choose Management & Governance > Application Performance Management. - In the navigation pane, choose Performance Monitoring > Components.
- In the filter bar on the left, select a region and an application.
- Click a component name in the Component column. The component details page is displayed.
- Click the Message Queues tab. By default, the KafkaProducer monitoring information of all instances is displayed.
- On the displayed Message Queues tab page, select a target instance and monitoring item to view the monitoring data in different metric sets.
You can also perform the following operations if needed:
- Set a time range to view data. Select a time range. Default: Last 20 minutes. Options: Last 3 minutes, Last 5 minutes, Last 10 minutes, Last 20 minutes, Last 1 hour, Last 3 hours, Last 6 hours, Last day, Today, Yesterday, Last week, Last month, and Custom.
- Click
in the upper right corner of the list. In the Table Settings dialog box, select or deselect columns to show or hide them. - Click
in the upper right corner of the list to export information. A maximum of 100 records can be exported.
Parent topic: Monitoring Component Performance Metrics
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
