Error Codes
Error Type |
Error Code |
Description |
Possible Cause |
Solution |
Parameter error (APM.00XX) |
APM.0001 |
%@ is null. |
%@ is null. |
Set the parameter and try again. |
APM.0002 |
%@ is invalid. |
The type or format of %@ is invalid. |
Set valid parameters and try again. |
APM.0003 |
The length of %@ exceeds the maximum value of %@. |
Too many characters. |
Modify the parameter and try again. |
APM.0004 |
The value of %@ must be between %@ and %@. |
The value is out of the permitted range. |
APM.0006 |
%@ doesn't match pattern. |
The parameter does not match the regular expression. |
APM.0007 |
Invalid configuration parameters. |
Invalid parameters. |
APM.0008 |
This feature needs to be enabled in the configuration file. |
The feature is disabled. |
Enable this feature in the configuration file. |
APM.0009 |
Unsupported region. |
The region is not supported. |
Switch to the cn-north-4 region. |
Integration error (APM.01XX) |
APM.0100 |
The APMSDK is not initialized. |
The SDK has not been initialized. |
Set valid parameters to initialize the SDK. |
APM.0102 |
The APMSDK requires %@ or higher. |
The OS version must be %@ or higher. |
Ensure that the OS version meets requirements. |
APM.0103 |
Open database failed, code=%@. |
Failed to open the database. |
Handle the problem based on the SQLite 3 error code. |
APM.0104 |
Create database table failed, code=%@, error=%@. |
Failed to create the data table. |
APM.0105 |
Insert into database failed, code=%@, error=%@. |
Failed to insert data. |
APM.0106 |
Delete from database failed, code=%@, error=%@. |
Failed to delete the data. |
APM.0107 |
Select from database failed, code=%@, error=%@. |
Failed to query the data. |
APM.0108 |
Close database failed, code=%@. |
Failed to close the database. |
APM.0109 |
Reduce database size failed, code=%@, error=%@. |
Failed to reduce the database size. |
APM.0110 |
Begin transaction failed, code=%@, error=%@. |
Failed to enable the transaction. |
APM.0111 |
Commit transaction failed, code=%@, error=%@. |
Failed to submit the transaction. |
APM.0112 |
The count of database records exceeds the maximum value of %@, will delete %@ records before inserting. |
There are too many logs. |
Automatically delete old logs before inserting new logs. |
APM.0113 |
Update column(%@) to database failed, code=%d, error=%s. |
Failed to update data. |
System error (APM.02XX) |
APM.0202 |
Write to file failed. |
Failed to write the file. |
Check the permissions on the file. |
APM.0203 |
No file read and write permissions. |
Grant the read and write permissions on the file or directory. |
APM.0204 |
Call the system API failed, API=%s, error=%s. |
An error occurred when calling the system API. |
Handle the problem based on the error description. |
Network error (APM.03XX) |
APM.0300 |
Request failed, response code=%@, error=%@. |
Failed to send the request. |
For details, see Status Codes. |
